Heat Sink Accessory
Vaaman board provides a heat sink accessory to dissipate heat from the board. The heat sink is made of aluminum and is black anodized. The heat sink is attached to the board using 4 M3 screws. The heat sink is designed to dissipate heat from the board when the board is used in high power applications.
