Vaaman GPIO Description
Vicharak Vaaman board features a 40-pin GPIO (General-Purpose Input/Output) header that provides flexible options for connecting and controlling external devices. Through software settings, you can configure these pins as either input or output, making them adaptable for various applications.
Out of the 40 pins on the header, 27 are dedicated GPIO pins. These GPIO pins can also be repurposed for SPI (Serial Peripheral Interface), UART (Universal Asynchronous Receiver-Transmitter), and I2C (Inter-Integrated Circuit) functions.
This versatility opens up a wide array of possibilities for interfacing with different components and facilitating communication with other devices.
Tip
What? you want more GPIOs?
Fear not, we have a solution for you. Vaaman board has additional 40-FPGA GPIOs
available to the user.
These GPIOs are accessible from the FPGA and can be configured to be used inside
your project and applications
GPIO Voltage Level
RK3399 SoC has three multiple GPIO voltage levels. Below table shows the voltage level of vaaman GPIOs.
GPIO |
Voltage Level |
Tolerance |
ADC_IN0 |
1.8V |
~1.98V |
GPIO3_C0 (Pin 32) |
3.3V |
~3.46V |
Other GPIOs |
3.0V |
~3.15V |
Available GPIOs on Vaaman
Vicharak Vaaman board has total 80 GPIOs available for user. 40 GPIOs
are accessible on 40 pin header and 40 GPIOs are accessible from FPGA.
Below table shows the GPIOs available on Vaaman board.
Warning
Not all functions can be used at the same time. Only one function can be used or assigned to a GPIO at a time.
SoC GPIOs Header
GPIO number |
Function2 |
Function1 |
GPIO |
Pin# |
Pin# |
GPIO |
Function1 |
GPIO number |
+3.3V |
1 |
2 |
+5.0V |
I2C7_SDA |
3 |
4 |
+5.0V |
I2C7_SCL |
5 |
6 |
GND |
75 |
SPI2_CLK |
GPIO2_B3 |
7 |
8 |
GPIO4_C4 |
UART2_TXD |
148 |
GND |
9 |
10 |
GPIO4_C3 |
UART2_RXD |
147 |
146 |
PWM0 |
GPIO4_C2 |
11 |
12 |
GPIO4_A3 |
I2S1_SCLK |
131 |
150 |
PWM1 |
GPIO4_C6 |
13 |
14 |
GND |
149 |
SPDIF_TX |
GPIO4_C5 |
15 |
16 |
GPIO4_D2 |
154 |
+3.3V |
17 |
18 |
GPIO4_D4 |
156 |
+5V |
19 |
20 |
GND |
GND |
21 |
22 |
GPIO4_D5 |
157 |
+5V |
23 |
24 |
GND |
GND |
25 |
26 |
ADC_IN0 |
64 |
I2C2_SDA |
GPIO2_A0 |
27 |
28 |
GPIO2_A1 |
I2C2_CLK |
65 |
74 |
I2C6_SCL |
SPI2_TXD |
GPIO2_B2 |
29 |
30 |
GND |
73 |
I2C6_SDA |
SPI2_RXD |
GPIO2_B1 |
31 |
32 |
GPIO3_C0 |
SPDIF_TX |
112 |
76 |
SPI2_CSn |
GPIO2_B4 |
33 |
34 |
GND |
133 |
I2S1_LRCK_TX |
GPIO4_A5 |
35 |
36 |
GPIO4_A4 |
I2S1_LRCK_RX |
132 |
158 |
GPIO4_D6 |
37 |
38 |
GPIO4_A6 |
I2S1_SDI |
134 |
GND |
39 |
40 |
GPIO4_A7 |
I2S1_SDO |
135 |
Note
The default function of pins marked in orange are specific to this board. For example, Pins 3 and 5 cannot be used as GPIOs because they are connected to the I2C bus and are already in use.
All pins, except those for power supply, are directly connected to the System-on-Chip (SoC).
Pin 7 is directly connected to the
MIPI CSIpin on the board. Instructions to use UART2 as serial console can be found in Serial Console, and to disable it, refer to Vicharak Config Device tree overlays section.Both
UART2andUART4support a wide range of baud rates, including 115200bps, 500000bps, 1500000bps, and more.
FGPA Header
Function |
GPIO |
Pin# |
Pin# |
GPIO |
Function |
+5.0V |
1 |
2 |
+3.3V |
+5.0V |
3 |
4 |
+3.3V |
LVDS/GPIO |
GPIOT_RX28_P |
5 |
6 |
GPIOT_RX28_N |
LVDS/GPIO |
GPIO |
GPIO_73 |
7 |
8 |
GPIO_75 |
GPIO |
GPIO |
GPIO_173 |
9 |
10 |
GPIO_72 |
GPIO |
GPIO |
GPIO_174 |
11 |
12 |
GPIO_178 |
GPIO |
LED |
USER_LEDS3 |
13 |
14 |
GPIO_183 |
GPIO |
LED |
USER_LEDS2 |
15 |
16 |
USER_LED0 |
LED |
GPIO |
GPIO_63 |
17 |
18 |
USER_LED1 |
LED |
GND |
19 |
20 |
GND |
GND |
21 |
22 |
GND |
LVDS/GPIO |
RX29_CLK2_N |
23 |
24 |
RX29_CLK2_P |
LVDS/GPIO |
CDI |
CDI6 |
25 |
26 |
GND |
GND |
27 |
28 |
GND |
GPIO |
GPIO_168 |
29 |
30 |
GPIO_187 |
GPIO |
GPIO |
GPIO_17 |
31 |
32 |
CDI7 |
CDI |
CDI |
CDI5 |
33 |
34 |
GPIO_66 |
GPIO |
CDI |
CDI4 |
35 |
36 |
GPIO_62 |
GPIO |
GND |
37 |
38 |
GND |
+3.3V |
39 |
40 |
+3.3V |
::{note}
The default function of pins marked in orange is specific to this board. For example, pin 13, 15, 16 and 16 are used as LEDs and they cannot be used as GPIOs.
The pins layout from 29 to 40 follows the standard PMOD pinout. Check the PMOD page for more information.
LVDS/GPIO pins can either be used as GPIOs or as LVDS pins. To use them as GPIOs, refer to Vicharak FPGA LVDS. section.
CDI can be normally used as GPIOs.
GPIO Numbers translation
GPIO0 |
Number |
GPIO1 |
Number |
GPIO2 |
Number |
GPIO3 |
Number |
GPIO4 |
Number |
A0 |
0 |
A0 |
32 |
A0 |
64 |
A0 |
96 |
A0 |
128 |
A1 |
1 |
A1 |
33 |
A1 |
65 |
A1 |
97 |
A1 |
129 |
A2 |
2 |
A2 |
34 |
A2 |
66 |
A2 |
98 |
A2 |
130 |
A3 |
3 |
A3 |
35 |
A3 |
67 |
A3 |
99 |
A3 |
131 |
A4 |
4 |
A4 |
36 |
A4 |
68 |
A4 |
100 |
A4 |
132 |
A5 |
5 |
A5 |
37 |
A5 |
69 |
A5 |
101 |
A5 |
133 |
A6 |
6 |
A6 |
38 |
A6 |
70 |
A6 |
102 |
A6 |
134 |
A7 |
7 |
A7 |
39 |
A7 |
71 |
A7 |
103 |
A7 |
135 |
B0 |
8 |
B0 |
40 |
B0 |
72 |
B0 |
104 |
B0 |
136 |
B1 |
9 |
B1 |
41 |
B1 |
73 |
B1 |
105 |
B1 |
137 |
B2 |
10 |
B2 |
42 |
B2 |
74 |
B2 |
106 |
B2 |
138 |
B3 |
11 |
B3 |
43 |
B3 |
75 |
B3 |
107 |
B3 |
139 |
B4 |
12 |
B4 |
44 |
B4 |
76 |
B4 |
108 |
B4 |
140 |
B5 |
13 |
B5 |
45 |
B5 |
77 |
B5 |
109 |
B5 |
141 |
B6 |
14 |
B6 |
46 |
B6 |
78 |
B6 |
110 |
B6 |
142 |
B7 |
15 |
B7 |
47 |
B7 |
79 |
B7 |
111 |
B7 |
143 |
C0 |
16 |
C0 |
48 |
C0 |
80 |
C0 |
112 |
C0 |
144 |
C1 |
17 |
C1 |
49 |
C1 |
81 |
C1 |
113 |
C1 |
145 |
C2 |
18 |
C2 |
50 |
C2 |
82 |
C2 |
114 |
C2 |
146 |
C3 |
19 |
C3 |
51 |
C3 |
83 |
C3 |
115 |
C3 |
147 |
C4 |
20 |
C4 |
52 |
C4 |
84 |
C4 |
116 |
C4 |
148 |
C5 |
21 |
C5 |
53 |
C5 |
85 |
C5 |
117 |
C5 |
149 |
C6 |
22 |
C6 |
54 |
C6 |
86 |
C6 |
118 |
C6 |
150 |
C7 |
23 |
C7 |
55 |
C7 |
87 |
C7 |
119 |
C7 |
151 |
D0 |
24 |
D0 |
56 |
D0 |
88 |
D0 |
120 |
D0 |
152 |
D1 |
25 |
D1 |
57 |
D1 |
89 |
D1 |
121 |
D1 |
153 |
D2 |
26 |
D2 |
58 |
D2 |
90 |
D2 |
122 |
D2 |
154 |
D3 |
27 |
D3 |
59 |
D3 |
91 |
D3 |
123 |
D3 |
155 |
D4 |
28 |
D4 |
60 |
D4 |
92 |
D4 |
124 |
D4 |
156 |
D5 |
29 |
D5 |
61 |
D5 |
93 |
D5 |
125 |
D5 |
157 |
D6 |
30 |
D6 |
62 |
D6 |
94 |
D6 |
126 |
D6 |
158 |
D7 |
31 |
D7 |
63 |
D7 |
95 |
D7 |
127 |
D7 |
159 |
